I replaced the port outdrive in late October and still in the break-in period. I took the boat out today to rack up a few more hours and as I approached 3000 rpms, the port engine started surging, up to about 3400 down to 2800 with bad vibrations. Dropped rpms to 2800, rock steady, everything is fine! At this point I'm almost freaking out, have a spun out the prop (not probable, I haven't hit anything) is the outdrive bad, is the shaft from engine to the outdrive or u-joints going bad? What in the world is wrong!!! Drop engines into neutral, walk back to the swim platform to visually inspect the outdrives and what do I see, a small stick wedged against the swim platform support. As I go to remove it, the small stick becomes a 3' long branch about 1-1/2" in diameter. Inspect the branch, no chunks from the prop, in fact, the branch was making no contact with the outdrive. The lighbulb goes off. As I increase speed, the flow of water over the branch forces it lower into the water, DIRECTLY BEHIND THE PROP. Science in action, the stick was interrupting the "prop wash" (proper term?) and causing cavitation. Remove the stick, all is well, 5 hours into break-in, another 5 to go...
