Originally posted by AbsoLoot
Wayne,
I would certainly be upset if an engine mysteriously went bad. However, I think that I would do some investigative work before accusing someone on a public forum. I have never used the mechanic in question, but have seen many of his posts ans those of happy customers on other sites that i frequent. I've also seen you thank him for information here, hire him to do work, complain about the work and responsiveness, then thank him again and then cuss him out again saying that he sabotaged your boat. I think you'd have to be the first to admit that you are a very emotional person and tend to go off easily.
If he sabotaged your boat, he deserves to be outed and other boaters warned. However, as I mentioned before, the rope could have been in the water and got sucked up into the props either when he or you started the engine. In addition, an entangled line would have nothing to do with the engine not running properly. I really empathize with your situation, but as Les said, there are always two sides to every story. You have said that money isn't an issue, but I seem to remember other posts where the mechanic stated that you were going to continue to have problems until you got the water out of the fuel. There are a couple of ways to do this .... frequent changes to the fuel/water filter, have the fuel polished or have the fuel pumped out and disposed of. None of thewse solutions are cheap and I have to assume that you either didn't believe him or didn't want to go to the expense of performing them.
You also had the opportunity to have Charlie look at the engines so that he could help you out. If you've been around here much, you would know that Charlie is an excellent mechanic with a big heart. I understand that something came up and you were late in meeting with him or tried to change the time and ended up not getting together. You say that this is really important and that money isn't an issue, but you couldn't prioritize your time to meet with a guy that probably would have helped you out for the cost of a good meal. Treating someone else as if your time is so much more valuable than theirs is not a good way to create working relationships. I have to wonder if that played a role in the troubles with your original mechanic. Take a few minutes and review your past posts to see why I've formed this opinion.
I have heard good things about Diablo Marine. Hopefully they can fix your troubles and you can start with a clean slate with them. Remember just because they turn a wrench instead of what you do doesn't make them any less valuable and if you don't want to learn anything about your power plants, you'll have to trust them and not second guess what they tell you. Good luck, I really do hope it works out for you and the rest of your season is trouble free.
