Thru Hull Question
MarkMuck
Hello...I have a 1992 Silverton Express. I always get water in my forward bilge. My A/c condensation discharges in there. But over the winter I was getting water in there and the A/C was off.
I have one thru hull up there for the toilet. I'm wondering if it is leaking? The boat is coming out of the water next weekend for maintenance.
Here are my questions?
1. Does the seal around a thru hull go bad over time and likely cause a leak?
2. If I pull that thru hull should I replace it or just reseal it ?
3. What's a good sealant to use? How long for drying ?
4. Is it possible there is a hairline crack in the fiberglass that could be letting water in ?
Advice is welcome.... Thank you..
Mark
It may be a window leak.
It could be a lot of things.
could also be a rubrail rain water leak. You could sprinkle some talc around the thru hull and then wait and see if "tracks" show up.
Your really need to see if you can find the source of the leak before you go blindly caulking things.
While the boats out of the water you could fill the forward bilge with water and see if you see any leaks around the thru hull.
Is the thru-hull plastic?, or silicone bronze? If it is plastic and you decide to replace it, then you should replace it with silicone bronze notwithstanding the fact that you are in a fresh H2O environment. DO NOT use silicone as your sealant, no matter what.
Could be your anchor rode deck pipe.
Could be your hatch cover leaking.
Could be your fresh water lines leaking.
Could be your fresh water pump leaking.
I have a 1986 34C Silverton which is basically the same hull. I had the anchor deck pipe leak that let water into my forward bilge. The rub rail also leaked which was the major leak. Does you air conditioner drain into a sump drain or just into the bilge?
Thanks for all of your great replies. My a/c drains into the bilge. I don't like that. But I have not found a easy way to avoid it....
Mark
To fix the problem of the A/C condensation I simply ran a tube to the nearest sink drain, which in my case happened to be the head sink. Sinks are classed as grey water and most drain directly overboard. So, I ran a tube to that drain making sure it was elevated slightly and "molded" in a bit of an elbow to avoid sink flow back. Works like a charm. Forward bilge is dry.
Mark
MarkMuck, why not run a/c drain hose to shower sump; that'll keep at least that water out of bilge. Besides, fresh water goes rank after a while !
He said the a/c was not running at this time. It may not be the a/c water.
If you have an anchor pulpit, there may be a leak around the bolts or screws that hold it down
to the deck.
One question was what type of sealant to use. Isn't 3M 101 one of the recommended ones because it reacts with water to "reseal" itself?
