Thrust Washer
bmetros
Can anybody tell me the proper way to install a thrust washer on a Mercruiser 5.7L 230 HP for a Michigan Wheel Prop? I see pictures with the bevel or cut side facing out, but the instructions say tapered end facing in.
Thanks.
Tapered cone fits the inner propshaft taper. It faces forward. The stepped side faces the prop. There are 2 thrust washers with different size steps. Only the right one will work for any particular prop. Get both thrust washers just in case.
