Tidal preferences
Riverbed
Just curious as to everyone's preference when boating in unfamiliar tidal areas. Assuming you have up to date charts (and have actually looked at them), a tide chart (Eldridges), an accurate GPS and depth sounder, would you rather explore new areas at low tide, high tide, somewhere in between, or doesn't it really matter? And why?
Riverbed,
I would say that traversing a new area at near high tide would be easiest. You would have as much water as possible, current would be slowing down, you'd have slack tide and the top of outgoing before you had any real current to be concerned about. Then again if you ran aground you'd have lots of time to think about how you'll float off in 12 hours...
My .02,
Perry
on a rising tide to cover any mistakes.
Rising tide, which makes groundings "self-repairing" ( ie: agree w/ pdecat )
I prefer a low tide---even a minus tide---for exploring. If I can safely get the boat in a nook or cranny at a minus tide, I know it will fit when the tide is higher. And groundings are less of a problem, too!
I'm with OFB guy. 'Unfamiliar territory' is the key. Rocks and pinnacles that are exposed at low tide may be barely awash at high.
I'm askeered of venturing into the California Delta. Gimmee the open ocean where you only have to worry about the occasional crab-pot and frisky whale.
Awh, Charlie, a little local knowledge will take away those fears!!!! Now, me, I don't trust myself out in the big water. It's the weather and currents that I worry about there. Also, I like to be able to swim to shore if necessary! [:-doggy] [:-doggy]
I'm also concerned with the current and wind direction, so if I start to lose water I can shift to neutral and blow out. Billy K.
