Let me try to explain what is going on. The port is just inside the inlet. To the north and south are the ICW as well as various salt water lakes and canals. At high tide in the port, the points to the south and north are not yet "full." Water will continue to flow through the inlet to fill those remote areas, but the water will not get any higher in the port. Water is seeking its own level. Once the remote areas are full, there will be a brief period of equilibrium with no current. After that, water starts to flow out of the port, hence the slow current. Once the remote areas start to empty, the current (water flow) increases as well.
