tilt/trim switch
mrkatana
does anyone know how to replace the tilt switch thats mounted in the throttle handle? (quicksilver control)
I think Merc sold a bunch of different controls under the Quicksilver name.
Suggest you try a google search of Quicksilver control parts diagram and select one of the resulting images that most resembles yours, zoom it up & print to possibly help get yours apart & back together.
Have you ruled out trim relays as the problem?:
http://www.thehulltruth.com/boating...tilt-trim-switch-mercury-throttle-handle.html
Merc had so much trouble with the tilt/trim buttons over the years. They had some of the stupidest designers in the world. Last one I got talked into fixing, I found the owner just pushed the switch a little too hard and popped the switch out the back. After I stopped laffing, I got a piece of wood and JB welded it as a backing plate to hold the switch in place so it could make contact and not get pushed out the back again.
They're really simple switches so they can be fixed.
I have replaced both relays- the switch is loose and not 100%
I just cant figure out how to get the top part of the handle off- I search the internet extensively-and the repair manual only shows how to test the switch if the whole control box is out
Since there are several different controls out there it might help if you would post a picture. Maybe then someone would recognize it and be able to be more specificall helpful.
ok here is a pic/video---Does anyone know how to replace the tilt trim switch on this thing?
[https://www.youtube.com/watch?v=4OOAMZPbWG4&feature=youtu.be]
