All the above is true BUT. Prop torque can be tricky to dial out. One thing is, the tab on the motor will be pretty inefective at high cruise and WOT. If you are running at over about 40 MPH you might want to consider a "Torque Tab". It goes on the starboard side of the skeg at the trailing edge and takes out the pull to the right. They can be screwed on, pop riverted or best is to epoxy it and fair with Marine-Tex. Then trim the motor running position for max performance at WOT and see if it is running straight with equal pull in each direction. If it's pulling left now, grind the tab down a bit and try again. Still pulling right, you may need to raise the motor an inch or 2. 1 bolt hole up is about 1 inch. Be sure you have a water pressure gage to be sure you don't get to high and lose pressure.
NFB steering, and hydraulic, by far the best, will mask any feedback from your engine and prop to your hands, which is not necessarily the best situation. You won't know what it's really doing until you try to turn in both directions. It takes "seat time" to really get it right and really get to understand what's happening.
