trac-phone 252
mx8
The admiral gets all worked up when we are somewhere w/o cell phone service, which happens to be a lot of the places I like to go for peace and quiet, so I was thinking up combining this years boat upgrade/Xmas gift to ourselves by adding this system. She also is a web surfing junkie.
I know nothing about these systems. Do they have service everywhere, like advertised, is there a monthly or by the minute charge. Also, how complex is the install, it would be a great justification if I could bring it to the cabin in Vermont for the winter, which has no cell or internet, which gets her all worked up again. I also like going to the cabin, for peace and quiet, she is so quiet when she`s surfing.....
I don't have any info on this model specifically, but I got a trac phone for my father in law who lives near St. Johnsbury VT. It worked in Florida but not VT. I bought him another one in VT that operates on Verizon's CDMA system and it works in VT and FL. Don't assume that because it works in CT it will work in VT.
Where's your cabin?
The cabin is in the Groton State forest, actually in the town of Marshfield, probably 20 mile to St J., It would be not so good to get something that doesn`t work there.
The wife and I have both carried TracFones for many years. You buy minute cards, we get a 400 minute card every year for around $100-, if you only buy the smaller minute cards, 60/120 minutes you have to buy another every 60 days I believe. Go to there web site and punch in the zip code where you will be carrying the phone and they suggest several models, we both have Motorolas, the Nokias sucked. Paul.
the only difference between a hand held sat phone and one wired to the boat is you have to go outside with a clear view of the sky to use the handheld. if you are ok with that the handheld can be used anywhere including trips not involving the boat. the handhelds are way cheaper than the wired ones.
I don't think you carried this around Paul :-)
It's a Mini-M system. You're not going to be doing any web surfing on it. Email maybe. Minimum per minute cost is $1.49. And it's not portable.
"Inmarsat Satellite Product Data Speed Comparisons (w/out Velocity Acceleration)
2.4 Kbps (mini-M)"
Once you check out the total cost of ownership, you will likely have other thoughts. Where exactly are you having cell phone reception issues? I boated pretty heavily in your neck of the woods this summer and had no issues (AT&T); I very occasionally got out the Digital Antenna cell amplifier purely to boost data speeds. We need to have contact as much as possible and have only been out of it for a couple hours of cruising the entire east coast, in the wilderness of North Carolina's Alligator-Pungo canal.
You can rent an Iridium or Globalstar handheld and test drive the concept if you are really set on it. But me, I don't see the need for coastal cruising in US waters.
George
I have a TracPhone 252 because I need 100 percent coverage with my business. The 252 works everywhere it is a global permanent mounted sat-phone on the IMNARSAT network. They charge me by the minute I can't remember the rate the office pays it somewhere around $2.00 per minute. Prior to that I had a Globalstar and it was terrible it only worked 20 minutes out of each hour. They had problems with their satellite constellation don't let them fool you and tell you it's fixed, it is not. The cost per call is expensive. I only used it 5 times this year but it came in handy when I needed a solid connection. It's also great for getting faxes cellular phones do not get faxes at all because of the digital format of the signal. Our primary phone/internet is provided by AT&T and I would highly recommend using the Ericsson W-25 along with a direct connect amplifier and external Digital cellular antenna. The W25 also has a built in 4 port switch as well as WiFi and a digital phone line. I have 2 computers connected at all times when we are on the boat. I also have a Dock-N-Talk which hooks up my IDEN (Nextel) and it is hooked to its own unique dual band direct connect amplifier and Digital antenna mounted high on the arch. I also use a Syrens 1 watt high power WiFi unit and I can almost always find an open network. I need to be connected it's my business and if I want to spend a lot of time on the boat I need to be connected without interruption. My 3 boat phone numbers are hooked to a 3 line cordless phone system. One quick point don't get a handheld satphone for use on a boat you can have problems dropping calls. An in the clear permanent mounted unit works better by far. Regards Bill
mx8,
You'd be better off investing a few hundred in a cell phone amp and an antenna. I think Les carries Digital Antenna gear. I've got Wilson. While I do keep a Globalstar phone and subscription going on the boat (I know, Bill, you're right, it's only so many minutes per hour. But at $40/month unlimited this year and then $20/month the next 2 years, it works for me), I use my wifi amp and cell amp much when I'm cruising in home waters. My wifi setup is a bit complicated, but I did see 5milewifi.com written up in one magazine or another as decent for $400. Sticking with cell service, if you've got a PDA with data service, just use an amp with it and then tether the thing to a laptop. Boom, done!
Good info guys, I`ve considered the handhelds and may end up that route, I like the sound of the cell phone amp/antenna. I`m almost positive that will work at the cabin as the Onstar in my truck worked fine until GM "upgdaded" it.
The main problem area on the boat has been Menemsha, although I didn`t go this year, there have been a couple of other spots but I can`t remember exactly where.I thought that something that would work in both areas and allow internet access would be too good to be true.
Kurt I think I still have my permanent Globalstar I will look for it if you want it? I said I would never give this unit to a friend! The service is so bad they give you a website you put your coordinates in or zip code and it tells you when you may be able to use it and for how long.
Regards Bill
Here is the link for using your phone on Globalstar.
http://www.globalstar.ca/en/optimum_tool/
When we went over to the Vineyard a few times this year, we had coverage just outside Mememsha Harbor. We never went into the harbor, so can't speak with authority to that, but see nothing that would have degraded the signal in there, which I am sure the cell site was designed for. We saw our first big sun fish in Vineyard Sound mile NE from there, and went on line to try and figure out WTH it was. Bill, where do you go where the 252 is needed?
George
Sometimes between Atlantic City and Cape May there are spots where I don't loose service but can drop calls. I have had 5 really important conference calls this past summer with large groups of people on it and I can't drop out because I am the person running the call. If the meeting "leader" drops out everyone must dial back in. What can I say Sprints conference bridge circuits are strange. Otherwise the AT&T and Nextel phone service is quite good with my set up. I also had to do one fax that was done on the 252, e-mail and PDF's have really replaced faxes but again in my position I need 100% connectivity the 252 is my prime choice for the important conference calls and rare faxes. The audio quality is excellent but there is some time delay but then again there is also a time delay even with digital cellular phones.
George I planned on cruising down to and up the East coast until this economic mess hit so the boat was outfitted with redundant electronic and communication systems to be able to conduct business while I am on the boat.
Bill,
If you can find your permanent GS setup, I'd consider taking it off your hands for sure. You'd laugh at my setup. I bought their car kit so I could have an outside antenna. I put that on top of my TV antenna covered with a nicely seated 6" PVC cap. Honestly, it works great.
I know that darn tool. It does help when I want to locally test the phone. But when we're out of US waters, I don't have internet access a good bit of the time. I just turn it on and it will actually make a short sound when it gets signal. Truly for the current pricing, it works great. The admiral and I decided the stay subscribed to pump some money in as that $20/month the next 2 years it just too good to pass up. Especially when the second year (2010) they claim the new birds will be up. Who knows. But, as always, you're right. If you MUST HAVE service, GS ain't the way to go right now.
I posted the link to the tool above. I will look in my storage locker for the perm mount Globalstar PM me when you get a chance. Take care. Bill
Hey guys,
I need an interpreter.
I only recently got my first cell phone. I just took a look at the promotional Ad for tracphone(basic phone stuff) I find I don't know what they're talking about. They have an Motorola LG225 with a 1 year wireless and 400 minutes($99) AND a Motorola C261 with 1 year wireless and double minutes(800) for $139.
Does that mean I can get wireless internet service for the advertised minutes? If so, is it fast enuff to watch streaming movies?
Can you tell I'm a bit clueless?
Oops! Here's a link.
http://www.tracfone-orders.com/bpdi...locale=en&siteType=TR&gotoPhonelist=true&AID=
The Tracphone you got is not what we are talking about we are talking about a permenant mount satellite based phone system. However that being said Tracphone is a prepaid reseller they do not own any infastructure only a billing system. The phone you have is CDMA based so depending on your area you will either be on Verizon Wireless or AllTel. I believe Tracphone and Sprint parted company earlier this year. He are the potential problems with your phone if you travel world-wide it won't work most countries use GSM based cell service. If you don't travel abroad when you leave your home area your are charged double minutes depending on the plan you choose. Verizon has a great network and they just bought AllTel. I prefer AT&T because my unit will do UMTS data which is faster than the current EVDOrev.A which Verizon uses many AllTel sites are still 1-RTT which is very slow data wise. You need to check the plan and phone to see if you can get data. I'm pretty sure you can, in fact if your laptop and phone are both BlueTooth enabled you won't even need a cable to connect them. Most stand alone phones require a data cable and a data plan in addition to the standard voice plan. I have read just recently that to get data with Verizon you will need a data contract. I will do a little more research, perhaps George will comment (Caltexfla) he has done consulting like I do for various cellular carriers.
Regards Bill
http://www.tracfone.com/data/conversion.jsp Charlie; after you read this you will be very disappointed you are very restricted and can not tether your phone to any device according to their website. In my opinion you picked the worst possible service provider for true data services. If you read the contract restrictions you can only go to their URL in other words forget about surfing the web on your laptop connected to the phone, you will also notice under restrictions only data can be viewed on the phone you purchased and no other device. Give the phone to a relative and get a real plan directly from a carrier. By the way Verizon currently has data caps to discourage streaming video and they can terminate you if you hit the cap to any time. Many customers report being terminated by VZW for using to much bandwidth in a billing period. There are very few companies that offer all you can eat "data" plans. AT&T and Sprint have the wording but I have never heard of a single user being terminated unlike VZW. Good luck. Bill
Here is my list of the top data providers and equipment
#1 By far the best AT&T with the Ericsson W25 platform it gives you a phone line. fast UMTS internet, a 4 port router and WiFi 802.11B or G to rebroadcast it's own internet. If UMTS service is not available it reverts to the older 2G network.
#2 The Sprint Linksys router it gives you fast EVDOrv.A CDMA internet, WiFi to rebroadcast it in your boat and a 4 port wireless switch. If EVDO is not avaiable it reverts to 1-RTT service.
#3Kyocera KR1 gives you the ability to use either Sprint or Verizon, has a 4 port router and 802.11B&G for rebroadcast. Same here it will revert to 2G data if EVDO is not available.
These are all land based cellular systems that I have tested extensively in New Jersey.
I am partial to the AT&T Ericsson W25 because you really get a phone line as part of your package. All of the mentioned systems need external Digital cellular antennas mounted as high as possible and sometimes a direct connect amplifier be it Shakespeare, Digital or Wilson. I do not recommend the wireless repeaters (BDAs). Use an interface from Dock-N-Talk unit from your cellphone and then put a 5.7ghz wireless cordless phone system behind it. I can roam all around the marina with my cordless phone and get calls to the 3 phone line permanant systems on my boat.
#4 Syrens WiFi this is by far the best long distance unit I have found to date and if you find a spot with enough bandwidth for Skype phones. It has any easy interface unit.
#5 5 mileWiFi I have not tested this product yet but have ordered it this looks promising for etended WiFi.
#6 Enginius if your a programmer this is a good unit for WiFi, otherwise I wuould avoid it. It is far too complex for the average person to reset the unit.
With WiFi again use an eternal antenna and place the unit as close as you can to the antenna and with all the above systems mount the external antennas as high as you can.
I can and have typically gotten coverage from 10 to 15 miles off shore, exception being not the WiFi systems.
Stand alone cellphones really don't cut it unless you can get an external antenna cable and at least a Digital cellular antenna. Again don't expect anything to work with any degree of reliabilty if you don't have an external antenna, the amp is optional from inside the boat's cabin.
Take care. Bill
I'd like to add something, but Bill covered it all!
Cell amps and wifi amps are great if you're near land.
For cellular I have a Verizon PDA with data service that I tether to my laptop with a Wilson amp and Shakespeare external 4' cellular antenna.
For Wifi I have a 1-watt amp an 9dB omni antenna from HyperLink Technologies. I don't "repeat" the signal as it's only a 30' boat and one laptop is all we carry. Thus I connect the amp via a USB wifi card directly to the laptop.
Between the two of these options, I rarely don't have service while I'm on the Chesapeake (although there's a couple of anchorages where I still can't find either, but that's getting more rare each season). However, far enough offshore satellite is about all there is.
