2014 Mazda CX-9, I installed genuine Mazda tow light package, plugs into harness, add fuse at main block, clean install.
Replacing trailer lights, hooked up right only. Running light worked, flasher worked. When on together, the running lights cause the car's running lights to go out. Turn off then on and they reset, lights work again for about 10 seconds.
I called superbrightLEDs and they say it most likely is the CAN Bus sysem in car.
Does anyone have experience with CAN Bus?
My thoughts:
1) I only had one light installed not two
2) Auto computer is expecting incandescent
3) Need to reset computer by pulling battery cable?
My thoughts:
