Can you mix and or swap transducers from one MFG to another? And if you can how do you tell compatibilty? Have permanently mounted transducer in the hull for a Humminbird Matrix 12 which is a single beam 200 kHz 20 degree span and would like to use with a Garmin 546S. Will it work or will I damage the unit if I try?
