Need some information again...
I think the transmission shift cable broke (of course, in the middle of docking and with the transmission in reverse.... had to kill the engine but that also messes up maneuvering mid-stream). This is on a 1966 Chris Craft, inboard, Paragon HJ-7 transmissions and Ford 427 motors. I want to be sure that this is a broken shift cable before investing time and money. The lever at the helm moves just as it was before, not floppy, not stiff. Down at the transmission, the cable appears to still be attached to the transmission. When moving the lever from forward to neutral and from neutral to reverse, the linkage moves on the transmission, but it will not go from reverse to neutral to forward. That sounds confusing as I type this.
I have somewhat eliminated an internal transmission issue, because if I move the linkage to neutral manually, then the transmission is in neutral and if I put the linkage in forward manually, then the transmission is in forward. So, does this sound like a broken shift cable? Why would it be able to move backwards but can't move the linkage forward?
As far as getting her back into our home slip, I was able to lock the transmission in forward, giving me port forward and port reverse and starboard forward when I fired the motor up. We've gotten pretty good at the whole one engine docking thing... I'm always happier when I know I'm docking on one motor and can plan accordingly... the whole losing a motor/transmission in the middle of a docking is not so nice.
