You already know that your boat is capable of cruising at 40 or 45 knots all day long in six foot seas (assuming trip Yanmars). Unfortunately, you are limited in distance by its fuel capacity and, therefore, the amount of time that you can cruise unless you obtain fuel as the day goes by.
I would think that you would run offshore more that the ICW based upon the fact that she is more of an offshore performance boat at 48' with only a 12' beam, and she should be able to handle most seas that you would encounter unless there is a storm offshore that kicks up some seas or the wind gods have agita that day. Then you will, I would suppose, opt for running inside. And, with the Arneson surface drives, you will not have to be too concerned if the H2O gets a bit skinny because she is a relatively shallow draft boat.
Therefore, from Miami to Baltimore will take you all of three, to perhaps into your fourth day, and/or with bad WX offshore and if you have to use the ICW for great stretches at a time, then your ETA will extend by a day or two. If it takes you more than that, it'll be because you have taken your family, you are making it an adventure, and you are just "cruisin'" and taking in the sights, and that is not that bad at all.
Please let us know what you decide, or come back with questions?.....
