Treadmaster
Joeshoes
I am planning to tear up a portion of the foredeck withing the enxt three months due to soft spots.ABout four square feet.
Anhyone know where I can buy "treadmaster?"
I think that it might look better than painting the deck.
SailboatOwners.com advertises that they have Treadmaster. You have to get the deck reasonably fair after the repair, so that it is not telegraphed thru the Treadmaster. The Treadmaster will look much different than surrounding decks. There are a number of other ways to handle decks after repairs. These include fairing the new resin/glass and then rolling a thickened waxed gel coat. We did this on a reconstuction with 1" Nida core. We removed all of the balsa with a router down to inner glass. Put in 1" Nida core, and then two layers of 18 oz biaxial cloth. This gave a deck which was almost identical with the origional on that boat. We have also ground the entire deck smooth, then rolled on Awlgrip with glass beads, then a second coat of Awlgrip, without beads. This gave a very nice deck which has worn well. The third way is to roll on or spray on truck bedliner or similar products--flexiable, and makes a very good non skid surface.
Thanks Bob!
Where did you get the 1 inch nida core? Also did you have to support the deck from underneath when you were ripping out the old core?
Joe
I purchased my Nida core material at the Advanced Plastics location in Elberta Al, which is only 20 minutes from my home. It was cheaper than marine ply (and of course much lighter--and no rot!). It appears that Mahogany Co has a warehouse in New Jersey: 800-253 1103. This may be old--and so you might have to do some googling to find it--but there is definately a destributer for that area. The deck we were reconstructing was a cockpit and had a grid system on about 24" centers. We had the layers of cloth and mat on the bottom, There didn't seem to be any appreciable sag. We laid down a layer of mat, then the Nida core, and finaly the 18 oz biaxial. Each layer was wet out as we went. The Nida core has a mat scrim on both sides, so it bonds well to mat or cloth. The raw pannel has some flexability, but after the resin had set up, my son (240 lbs and myself at 180 lbs can jump on it, with no deflection).
If you want to put a factory looking non-skid on your deck, you can use a Gibco Flex mold. This is a flexible rubber sheet with the diamond shape pattern that you transfer to the gelcoat. One company that sells this is Mini-craft and they have a tutorial on their web site how to use it. This is how the pros repair damage to non-skid area of fiberglass.
