trim alarm
sd210
I am a newbie to boating. I hear a beep alarm as I trim up when cruising. Some times engine cuts back. Whats up? thnks
sd210..... welcome to the forum.....and the world of boating.
More info would help get you a better answer. What model ? What year ? What drive ? What type of alarm ?
But.....did you check the outdrive oil reservoir ? It should be at the " full " line.
Thanks, 2000 sundeck 210, 5.0 efi 240 hp.Could this be a trim up sensor so i dont overtrim?
Check that fluid level for sure. When getting up on plane the angle is severe and fluid levels can be exagerated if not completely full. I had this happen one time and the alarm went off and the guardian protection system cut the throtlle back so fast it spun the HUB on my prop. Check all fluid everytime out!!!
