Trim tabs
Brian
My tabs weren't working. I checked for fluid in the pump. There wasn't any. So filled to proper level. Ran it but they didn't respond. I did hear the pump running. So my question is do they need to be bled and how is it done with the boat in the water? I didn't see any indication of leakage inside the boat ..was expecting to see something on the outside...like a sheen on the water. Maybe I still will when they are running properly. Hoping it is just a minor leak ..something I can live with til the boat comes out in the fall.
Ours did that once, and all that was wrong is we had blown a fuse, replaced fuse and they started working again.
If they're Bennett's, they're self-bleeding. Run the tabs all the way down and then all the way back up. The leak (if it is leaking) is most likely ocurring from the upper hinge fitting-to-line as it passes thru the transom...very tough to spot. You may have remove the upper hinges and verify..you won't be able to miss it if it's behind the hinge...ATF all over the place!
Assuming they are Bennett's they don't need to be bled (not sure about other brands). Check their website for the electrical and trouble shooting guide it's pretty specific. I had this same problem (my boat is on a trailer) and it ended up being a leak in the fittings on the inside of the transom. The leak was on the starboard side stopped all movement on both tabs. The fluid is ATF so I would think you would see a sheen if one of the rams is leaking. It's a pretty simple system - so fittings on both ends is where I would look.
They are in fact Bennetts.(Old Ones..85 vintage) So if I run them up and down a few times the will self bleed. If there is a leak other than the rams I will see it on the inside. Correct???
