Trojan 440 Express anchor locker drain location
subsonic
Hi Guys
I've noticed a little water building up in my anchor locker and I've looked but I am really struggling to find where the drain is to unblock it.
Any ideas?
Most lockers drain to the outside of the boat, not the bilge. Look around the bow area for a drain hole, should be obvious
I figured the same. I have a small rot spot to repair on the small shelf that is in the locker cupboard which has let some go down to where the archer chain is. I emptied all of the chain out and cant find a hole anywhere.
It is much easier to see from out
Side the boat the should be two one port and one starboard. Mine have very same and easy to clog with mud. You my want to try a 22 calorie barrel brush should work well. Or you can lower your anchor and all the chain then vacuum out the locker scup out any mud and you should be able to find them. You may be able to clear them with a hose once it is emptied.
Ah, got it. I did see them on the outside but was focused on the base under the chain!
Thank you.
Thank you.
We have all been there!
