Originally posted by jmeirhofer
That is strange Allen. What kind of Benny do you have? I am curious as to how that is wired to provide two 50A circuits as well. I only have two circuits but they are both with one cord, a 50amp 125/250v. Essentially two 25A circuits I guess when it is plugged in at a 50A connection. When I use the splitter to combine to 30A connection I guess I get 30A per side. At any rate one circuit is the AC and the other is everyting else. With both AC running it will jump just above 15 when one cycles on but otherwise holds steady around 10-12. On the other side with the water heater, stove, refer and microwave plus lights I will barely get to 15. With reasonable power management I think I could get away with just one 30A leg for the whole system.
I was just thinking, two and half years ago when I bought this boat I was trying to figure out how one cord had two circuits. LOL
Allen, you are killing your engines at those RPMs. You should get 2750 at WOT. If you post your issues on Boatdiesel.com, you'll get answers for free. Tony Athens there is an expert on Cummins, I guarantee you he will walk you through the process of getting you the correct RPM.
The speed number is probably with an empty boat, no fuel or water... I can get close to that number, but I never run at WOT.
Tony Athens is the man when it comes to all things with marine diesels!
He is a great guy and has a wealth of accurate information. If I ever re-power or get a boat with diesels I will once again consult with Tony.
I am guessing he did not have a hand held or digital tach to verify rpms?
