John do you have a floor for the center line of the bilge?
I got my dash back today it looks great I will post some pictures when I finish the install. I may have a couple I took at the shop I will see. Today I installed a water valve on the fresh water feed to the water pump. The other day I found I had a crack in the strainer before the pump and when I went to remove it water was flowing from the tank, it occurred to me it would be a good idea to have a valve there. I need to replace the strainer but at the moment I'm just feeding it without the strainer. I held pressure for two days and lost no water so I'm assuming I have no leaks this year, this may be a first. I installed my IP camera today this went well. Then I cleaned up my engines a bit everything is moving right a long. I plan to change my engine zincs this weekend and maybe I will do my impellers as well, this will only leave changing the oil and filters on the trannies and I will be done and ready for the season.
