Thanks Todd, do you happen to remember which model of lights you bought? I was planning to use the Orbit downlights, since they appear to look very similar to stock, plus they are IP67 rated so I know they can handle outdoors/wet. However, they use a mounting base that requires three screws. You said you used ones with spring loaded clips. I see that some of the Lumitec lights use spring clips, but the one I looked at (Mirage I believe) did not say it was IP67 rated, and I know there is a lot of talk on these forums about moisture/water getting inside the radar arch.
