Trying to understand propellers
Injam
Hello,
I'm trying to understand propellers. If you have two identical boats, but the outboard horsepower ratings are different. One boat has a 200 hp and the other a 250 hp. Both motors have the same Gear Ratio. If the propellers are identical and the RPM of the outboard is the same on each boat. Say 6000 RPM. Because of the weight advantage will the 200-hp boat be faster than the 250 hp? I'm thinking less weight less slippage otherwise they would be going the same speed.
