- Aug 5, 2008
- 30499
- 6,405
This device would not work (or at least be practical) in this application. John is looking to send an antenna signal wireless to his boat this device you are referring to is something that is used to transmit an already received signal back out to an additional TV and then it would be tuned in on a preset channel like channel 3 or 4. This setup would require having power and a cable box on the dock then using the rabbit to transmit the signal to the boat. This seems like a lot of work to avoid running a cable to the dock! Keep in mind you would have to go out side to change channels. The rabbit was popular in the late 70s early 80's when VCRs where just coming out and were expensive so most homes only had one this was a way to play the VCR thru out the house. I had a couple of them back in the day I later used these to broadcast cameras in homes it was a handy device.
