TWIC Card?
Ed Dippel
Hello,
I currently hold an O.U.P.V. near coastal license. I currently am not running charters and have no need to access restricted ports. Do you know if I still need to get a TWIC card?
Thanks.
You only need your TWIC if you are using your license to take passengers. If you are not actively 'using' your license, you don't need a TWIC, however, your license will be in a sort of limbo state unitl you get a TWIC card. You can not renew your license without the TWIC card.
So, if you just got your license, you have 5 years, actually 6 if it's inactive, before you actually 'need' the TWIC.
Rommer and dominic,
Thanks. I don't understand it, but thanks.
It almost sounds like companies that are trying to return bailout money to the government but the government won't take it to keep you under their thumb.
Originally posted by KiDa
Rommer and dominic,
The basic reason is because the government contractor that runs the program convinced the government to make it mandatory so they can make more money off of it.
Follow the money...
Here's the kicker (I have my TWIC fwiw) the card is issued by the TSA. ASo you are know to the TSA. Your background, identity, finger prints picture...everything. WTF can't I get expressed through the airport security?
http://www.uscg.mil/nmc/announcements/TWIC_Information_Bulletin_%2013Feb.pdf And your license may not just be in "a sort of limbo state" (whatever that means) it could be revoked.
"I know everyone is getting very tired of hearing about this, but for those of you that have not enrolled in the Transportation Workers Identification Credential (TWIC) program the deadline is coming up very fast. In fact the USCG is starting to ask for the credential when you apply for any Merchant Marine Credential. Beginning April 15, 2009 all individuals holding a USCG issued credentials are required to hold a valid TWIC. Failure to do so may result in your USCG issued credential being revoked. In addition the USCG will not except any application for an original issue or renewal of a USCG issued credential after April 15 unless the applicant holds a valid TWIC."
Sorry, but I need to do this:
TWICs are for kids.
Ok. Back to the discussion... :)
After 5 years, your license expires. You have one year to renew without having to take the test again. But the license is not good for that one year after it expires.
I have been in this situation before. That is how the USCG explained it to me. I renewed after year 5 but before year 6, but my stuff was lost during Hurricane Katrina. I had to operate with another licensed BCO with me at all times. They said my license was not good until I received my new hard copy, which was lost in space somewhere.
The USCG said that in order to keep my license, I had to have a TWIC. I did what they said, I didn't want to find out what they will do with my job if I didn't get it.
Yes. Anyone holding a Mariners credential of any kind is required to obtain a TWIC before 4/15/09.
I'll explain....From my experience, many folks who have a captains license, do not use it to carry paying passengers. They just have it. Until the TWIC card came around, the license was active and the captain could use it at any time to carry paying passengers. Once TWIC becomes mandatory next week, you can no longer use that license to carry paying passengers without a TWIC card, but, your license doesn't becomes void...you simply need to get a TWIC. If you have no intentions of using the license to carry paying passengers, then there is no immediate reason to get a TWIC card....until that is....you need to renew your license. No new or renewed captains licenses will be issued by the USCG without the TWIC. Hence, the Limbo statement.
Rommer and dominic,
Follow the money...
Now THAT makes sense.
I'd like to see that in writing somewhere. Because from what I have seen in writing your license can/will become void or be revoked without a TWIC card.
Just because you are not using your license does not put it in limbo or in some kind of inactive state. It's still active even if you are not using it. It only becomes inactive during the 1 year grace period.
"Who needs a TWIC?
The following individuals must obtain a TWIC:
1) All credentialed U.S. merchant mariners with active credentials. This includes all persons
holding a Coast Guard-issued Merchant Mariner License, Merchant Mariner Document, or
Certificate of Registry;"
"Will these rules affect all Merchant Mariners?
Yes. All credentialed U.S. merchant mariners must obtain a TWIC. This includes all persons holding a Coast Guard-issued merchant mariner's license, merchant mariner's document (MMD), Operator of Uninspected Passenger Vessels (OUPV), Standards of Training, Certification and Watchkeeping (STCW) Certificate, or certificate of registry (COR). With the implementation of TWIC, the Coast Guard MMD would primarily serve as proof of professional qualifications."
It seem's pretty black and white to me.
If you have the license, you need the TWIC card.
Rommer and dominic,
Follow the money...
That's the impression I got!
