So I won't be tackling this issue myself but wanted to get some input from the many experts on the forum.
Engine: 1998 Volvo-Penta 5.0GL Engine code 5GLPBYC41101628523868854 (electric fuel pump)
Issue: When starting either the starboard or port motor I pump my throttle a couple of times and fire up the motor. With my starboard motor, now it starts fine but when I bring it back to idle it dies. Pump the throttle a couple more times and it fires up again with same results. If I start it and keep the throttle above 1200 rpm until the motor is warmed up I can finally bring the rpm back down to idle speed. I had noticed last year at the end of the season that when putting the motor in gear I would have to goose the throttle a little higher right after engagement to keep it from dying but could then bring it back down to sync with the port motor.
So, anyone have some general thoughts on the problem? If I haven't put enough information in please let me know.
Thanks _ James
Thanks _ James
