i no 2psi turns light off. but how much pressure will that v drive develop? i thought i seen 6 to 12 psi? i want to make up new hoses.see what pressure to buy thanks
For the best answer, I would go straight to the horse's mouth. Contact Walter directly-they will be able to tell you. My '89 Walter V drives are probably a decade newer than yours and probably have a totally different set of specs.
