Out of Town
- Jun 14, 2014
- 33659
- 4
I have a 70 Trojan houseboat I am repowering. Going back to original setup. Chrysler 318's, one is counter rotating, there are velvet trans behind them and remote Walter V drives. Guy I got boat from said marina had went thru V drives while trying to diagnose eng. problems. Owner passed away and wife waited awhile before giving boat up to marina. There are new hoses and oil looks clean. I noticed some oil seeping from bottom side of starboard V drive. and wanted to get it fixed before adding eng. and relaunching. I noticed input shafts are loose on both drives, mostly up and down, seals look wollowed-out, but are dry(probably not run for very long time). I could get exact numbers off them, but as posted, these are extremely heavy, about 100-125lbs. 1st real questions is: Is this normal and something to do with input alignment? 2nd question is: Starboard V drive has a collar and bolt on top that says "rotate to align" the Port side has nothing but a threaded empty hole. Is the collar and bolt missing?
