Waste and Fresh water indicators
Ikhanton
Can someone tell me how I would go about getting the Waste tank and Fresh water tank level indicators installed for a 2000 2460?
For your waste tank level, the best way is to open your engine room and look at the level in the tank...I suppose you check the oil level everytime you intend to ride your boat, so it's a good idea to look at your waste tank then.
Concerning the fresh water, it's more difficult as the tank is under the forward cushion in the 'dining room'. You can remove this cushion (two small screws on left and right in the front of the cushion, underneath the lateral cushions) and see the reservoir through a small hole. Not very easy to install a transducer this way.
Everytime I take the boat, I fill up the fresh water reservoir (and I have a 6 gal. 'reserve' on board, just in case...)
