- Nov 30, 2006
- 24397
- 230
I have a '99 Wellcraft martinique 2600. There is a switch in the bathroom which in the down position turns on the water pump and the up position says head. It's a vacu flush head and you can hear the pump run when switched to the up position.
There is nothing in the manual describing this so do you normally leave the switch in the up position when on the boat (which I guess keeps the vacu flush operating and water pump going)? I've always just flipped the switch up when someone is going to use the bathroom and then switch it back off because I'm not sure the vacuum pump will shut off. How long does the vacuflush pump run before reaching proper vacuum? Maybe I have an airleak somewhere.
