I have a Seaward 11 gallon water heater that started to smell. Can some one tell me were to find the anode I think it is a peace on the cold water in let or is that a check valve?
Are you sure you even have anode? When I installed a new water heater from that manufacturer, it didn't have one. They gave a recommendation under what circumstances it should/could be be added.
If the drain tap is still there---no anode. Water in the hot water tank can smell like rotten eggs if not used enough and has nothing to do with an anode.
I've had smelly hot water in the past. I'm on a trailer and did not fully heat up the water with the portable generator. Once I got the water up to temperature the smell went away. I now make a point to get the water heater fully hot when I prep it for use for the boating season.
