Waves
When reading bouy info it gives the wave height and duration. Is the duration peak to peak, peak to trough or trough to trough.
Duration of one full wave. ie: it is peak to peak, or trough to trough. It is -not- peak to trough ( one half wavelength ).
I have always wanted wavelength, which, imho, very important. Unfortunately, this requires velocity, which is not provided.
An 8ft sea, with a wavelength of 36 ft would be very unpleasant, but an 8ft sea with a wavelength of 236ft might be considered nearly calm.
They give us height/seconds out this way.:D
I consider good fishing conditions with swell duration twice the height or 6'/12 sec or 10'/20sec with wind under 15 kts and wind waves under 3'...but I'm a poopbutt.
I look at the forcasted winds. Wave frequency is really important. The winds will start whipping the tops off, and then it gets really hairy. The Peak to Peak cant be reliably established in a "High" (blue bird day) because they dont always come at you from the same direction.
That's a bad place to be in a small boat.
