west inflatable
cpro
West inflatable 2000 9.5ft inflatable floor. will this boat last afew more years. seems to be in good condition now. thanks
POS !
i have a 99 Zodiac by west, saw very little used every couple of month) for the first 5 years and was stored in Aircon'd cabin. soone after the 5 year warrranty expired, it started leaking at the transom/floor corner. then over the following year, the floor started coming apart.
it's very hard to repair since the tabs on the floor are very small.
I thought I had read similar posts in the past. Pascal, thanks for the confirmation.
If it is a hypalon boat it will last longer than a PVC boat. West branded both Avon's and Zodiac which are similar (both are owned by Zodiac by the year 1998). I have a "West" 9.5 inflatable floor which is Hypalon and made by Avon which is a 2005. This boat will last a long time. I have a 2000 West PVC boat, (slat floor) which is holding up well, but it is deflated and stored after each use. If you do that boat will do fine. I have a 1992 Avon hypalon which still looks like new. If you leave a PVC boat out in the sun and heat inflated, it will have seam and leakage problems. I did have an older PVC boat (80's era" which came apart like Pascal's) and I gave it away--but I had 9 years good use out of it by this time.
Some of the earlier air floors had problems with the strings on the drop stitch floor comming loose, and causing uneven surfaces--once a few of the stitches give, others will follow. The newer boats are better.
We have a 2002 Mercury 310 Sport...
We keep it covered, in the water as we can not flip it up on the platform.
The boat cleans up well each fall, and everyone asks me if it's brand new?? It's not, but it looks it. So far, we've been very happy with it.
bob, mine was also deflated, rinsed and stored in the AC'd cabin after each use and it wasn't used more than 5 or 6 times a year ! it was a 99... maybe i was just unlucky :-( pretty sure it was PVC... it was the smallest roll up i could find, i had jsut enough room for it to fit in a storage space in the mid cabin (37 express)
i simply dont' understand why they used such a narrow strip to hold the floor to the tube. they're about an inch wide, there is 2 of them (one up and one down). had they used a wider strip, it woudn't have come apart and would have been easier to repair.... got to wodner what some manufacturer think sometimes...
I have a 2000 Avon hypalon. Outdoors 6 months a year on dingy davits. No problems. Previous was an Avon that I owned for 10 years. Just started to show signs of where. Newer is inflatable floor.
