On my 2001 Carver 570 Voyager does anyone know the make or brand of the plank flooring used in the Galley area? Last Summer (dock lost power) ice melted & leaked onto floor & a few boards curled that now need to be replaced.
Originally posted by aholst1
I would be concerned about changing out some of the flooring and the new not matching the old. If I was a betting man, my guess is RamSport will have an answer...
That's why I'm asking what brand in order to match it? Worse case, I can just pull out the wood & put in Granite. It's not a large area but I'm afraid the Granite may crack with a little movement.
Originally posted by Robyns Nest
If you don't want to go thru this again, replace it with Amtico flooring and they won't buckle when they get wet again. Most of the other home versions of laminate flooring will have this problem. Amtico is used on all high end boats and yachts for a reason.
Do you really think you'll never loose power again?
You will spend a few extra dollars now but will never have to replace it.
