What size generator?
32carv
Well-known member
I am looking to pick up a small generator that I would only use once per year to detail my boat. My buffer is a 10 amp buffer. What size / model do you recomend?
Would suggest a 6.5 horsepower unit. Remember you can only pull half the rating of the generator from each plug on most cheap units.
The Honda 1 or 2K iu units will serve you well. Very quiet.
IF your only using it once or twice a year how about a inverter hooked to your car. a 1500W inverter is cheap you can run it directly from your car battery. just hook it up once a yr when you need it. I installed one years ago on my truck and I ran wiring to several places in the truck front one outlet in the dash, one in the mid seat area for the kids game system etc. and an outlet in the back where I have pluged in a Microwave , refrigerator, and many other things like a 3HP air compressor. just let the car Idle and it will provide all the power to it you will need for Major loads and for small loads you can run quite a while with the engine off. Its always handy to have 110V availible all the time in the car.
olive juice, relax. Your first post is just fine.
It was the second one that you screwed up. :) Welcome to the forum!
I have a Honda 2000 which i use on job sights and used on my old boat, should be more than enough for what you need. I would check internet for used ones.
you can delete double posts, jsut click on the trash can icon...
I agree about using an inverter... if you dont' need the genny for anything else, an inverter will do the job, cheaper, no worry about old fuel, etc...
An inverter would work but at 10 amps at 120v, that equates to 100 amps at 12v. It wouldn't be long before you drain the battery. You'll have to keep the vehicle running.
I think a small generator would be a better choice: buy, rent or better yet is to borrow one. The good thing about owning a small generator is for times when the electric goes off. You can keep the fridge/freezer going, provide some heat if needed, lights, and TV (not all at once). The biggest downside of a generator is that they sit a long time and may not run when its needed the most.
