I like to think of my cooling system as a whole. All the parts have a shelflife and I tend to treat it as a system. The last time I gave significant attention (other than impeller changes) to my system was about 4 years ago. For me, that's about my expected life between overhauls. Here's what i'm doing: (this weekend in fact)
1.) Rebuild the raw water pumps (bearing and seals)
2.) Pulled the exhaust hose off the risers and clean out the "shower heads". The raw water enters the exhaust in a series of holes around the perimeter of the riser outflow so as to evenly disperse the water. I already found about a quarter of the holes plugged. They are small, so it does not take much.
3.) Inspect the risers themselvs. They are 4 years old cast iron, so I'll probably plan on replacing after next season.
4.) This weekend the end caps come off the heat exchangers and they will be rodded out. With any luck I'll be able to do it in place, as I can't slide the tube bundle cores out of the heat exchangers without dismounting then entire 80 pound units, and that's a major pain. The cooling tubes need to be fully free of concretions and debris and after 4 years, I'll find quite a bit of crud in there when they come off. Gaskets were ordered on Monday and arrived yesterday.
5.) Time to replace the coolant (antifreeze in the blocks)
6.) Inspect all the hoses (all changed 4 years ago, should be fine).
This pretty much brings my entire cooling system up to date, tip to tail. Other than impellers which may not last 4 years, i don't like to go through them piecemeal. I find that at the end of 4 years, all parts of the system need one degree of attention or another. End of last season, my starboard engine was starting to show telltale of more steam than usual. The shower head plugs would be enough on its own, but I suspect the heat exchangers themselves will show a need for attention.
In your case, the high temps at idle suggest a plug in one or more locations. Check for a) plugged intake screen, b.) missing pieces of the impeller (if you don't automatically chase down every single tiny piece missing when you change them, they go to the heat exchanger) c.) old zincs plugging the h/e d.)hoses collapsing on the inside (hard to see this happening, but suspect ANY old hose). d.) The risers themselves or the shower heads if your riser outflows are small (mine are about 1/4 diameter).
Good luck. Gotta love spring commissioning.
