windless adjustment?
aquahauler
I have a vertical axis style windless on my boat. I used it for the first time this year and found it would not retract the rode if there was any weight on it at all. I had to feed the rode because it was slipping. The road was not slipping, it was the outer housing that the rode rides in that was slipping around the axis. From that I figure there must be some type of clutch and hopefully a way to adjust it. Although I did not take a look, I would imagine if there is, it should be relatively simple. Anyone have any info
Had this happen once on my SL Horizon 500. Tightened the allen set screws on side of housing and that solved it. FWIW. Good luck,
Ron
Yes, somewhere (usually on the center of the gypsy) is a nut or screw that would tighten the clutch. My Lewmar 700 is a large allen bolt head.
Our maxwell windlass comes with a large hex (torx?) head wrench for tightening and operating it manually if necessary.
