windless question
marcgin
I know when you anchor you have to leave at least a 5 to 1 scope, however how do you know how much line you have out ? My anchor is all chain. Is there a rule of thumb for how long you hold down the swithch how much of the anchor line is being used ? or do you actualy have to put marks on the chain ? Since it is all chain I have a hard time knowing when it touches bottom ?
Thanks -
marking the chain is not a bad idea. Over time, at least on my current and past boats, I just kind of got a "feel" for how much had been let out of the windlass. From my helm I can watch the rode leaving the windlass and so can kind of get a good idea how much is out. That, combined with visually looking at the angle of the rode as I back down on it. I think they make a rode counter that you can mount at the helm but a lot cheaper to mark the chain with paint or something.
Marking the chain is the easiest way. I check my depth finder and if it says that I am in 20 feet of water I let out that much chain and assume that it is on the bottom. Do the math from there and it will tell you how much more to let out.
I think that marking is a good idea. I intend to do this some day, but now sure just how to do it. I will probably bow dock so I can stretch the chain on the dock. If I use spray paint to color code say every 20 feet will this paint stay on the chain for long?
George
obviously marking your rode is must, otherwise how do you know you have enough rode!! you can also use an electronic chain counter at the helm but marking works just as well and cheaper...
i use short paint mark (6") for each 25' and a long (12") for each 100'.... so 3 short = 75... 1 short 1 long = 125, etc... works well.
the key is to use a color that's visible at night... orange fluo works better than yellow which doens't show well with a spot light.
some use colored nylon ties instead of paint but they're too hard to spot from the flybridge or at night.
the first time aroud you need to stretch the chain to measure it although later on, when you need to touch up the paint (it wears off) you usually dont' have to remeasure. If your locker is big enough, you can usually measure the chain in there by stretching it 2 or 3' at a time.
Not quite what you're asking, but useful.
Another lesson learned: I'm so anal about everything that I do with the boat that I tend to hit (with a color coded line) within a 12” patch on the anchor line for each scope that I use regularly. The problem is that I now have significant chaffing in my rode at the 5 to 1 and 8/10 to 1 lengths of rode due to the frequency of use and the fact that I was swinging with the windlass carrying the load.
I just learned (thanks to tcijoe) that I should make fast to a cleat or set a bridle with my rode after deploying so I don’t wear through the rode at the bow roller and/or potentially break a gear tooth on the windlass motor.
bridles are good in heavy weather... in light weather (under 15kts) they're really not needed if you can just cleat the rode off the WL.
your rode shoudlnt' be chafing on the roller which is smooth unless you have some sharp corners on the edges of the pulpit/roller and it gets caught there.
i believe he was chaffing because of the windlass jaws...not because of the anchor roller.
Yep, that's it. Didn't know what it was called [B)]
actually i believe the real name is gypsy...but i am not sure on that. most people understand "jaws"
Has anyone tried to estimate scope by timing? If your windless is not the freefall type, it seems to me you could determine how much rode is let out per minute. Then time factor x by time to estimate scope. Is this doable? Comments please.
i do not see it possible..at least for me. as i let out my chain i back down a bit. i wait until the chain get snug then let more out, and repeat until i get the desired "angle" on the water that i want.
if i were to just dump for XX seconds my chain would pile on the bottom and never set my anchor.
i am a firm believer in setting your anchor a little at a time, then finally sinking it hard with both motors in reverse.
I see your point. I have never actually tried it. I was just armchair anchoring.......
I too usually judge my scope by the angle of the rode to the water. My bow anchor needs more scope because my bow is up high and the angle stays closer to 90 degrees then my stern anchor.
yes you can, although battery voltage and/or fast/low idle may affect windlass speed... marking is much more reliable in my opinion...
normally, as long as you have a little breeze, say at least 5kts, and if you give a brief impulse in reverse, the boat's motion will be enough for the chain to lay on the bottom and when you stop the windlass the anchor should set pretty quickly having the perfect pull angle.
it all depends on what you anchor in and your anchor type. With a Danforth for instance, if you back it up too fast or with insuficient scope you drastically increase your changes of weeds or debris or mud to clog the anchor and not set at all.
how much reverse to use to set the anchor also depends on the boat. with a larger boat and big diesels/big props you dont' really need to put both engines in reverse as that will be too much pull. it depends.
marcgin; i converted to all chain a few years ago and depending on the bottom conditions and the size of the waves i have generally found that a 3:1 to 5:1 ratio has served me well. i've never anchored in high wind and seas to know if a 5:1 was sufficient in the worst conditions.
on a different note it is very important to use a bridal to secure the chain to the boat. most windlass's are not designed to carry the full test weight of the chain and transmit that load to the deck of the boat. in fact it could damage the windlass to try. a bridal made of 3 strand nylon will give you some stretch that the chain does not have. i also use a short bungie cord on the bridal to further add some shock absorbtion. it makes a bid difference at night, no noise from the surge over the anchor roller.
pascal -- if you anchor can not hold with the force of both engines in reverse how do you know it will hold if/when the wind picks up??
i can see the additional force being placed by a larger boat with larger diesels...heck you idle at 7 knts however on the same token you will create much much more drag if the wind picks up.
it's not that the anchor doesn' hold with both engine idling in reverse...it does but it puts a lot of strain on the windlass. With both engine in reverse, my windlass clutch will slip a little and I know than even in 30 to 40kts winds, it doens't slip. so i'm not too worried...
I never use less than 6 or 7:1, more in stronger winds so the catenary absorbs whatever shock from winds or wave just as good as a bridle.
oh i guess i missed that part....i only twin engine reverse if i am on the bridle
i would not like that much force on my windlass either...sadly it would probably hold it.
