Windshield Leak
BillyBo
I posted a few weeks ago regarding a leak in my winshield that was seeping down into cabin(310 Larson). I took all the screws out, I lifted the windshield (I didn't remove the whole windshield) to find an "extra" set of holes beside all the screw holes, this is the obvious source of my leak.
My question is, what would be the best way to plug all the "extra" holes for good, I assume I should also put calking down the holes for the screws.
Thanks in advance
If your boat is still under warranty, I would take photos of what you found and contact the manufacturer regarding the problem.
A second alternative would be to purchase an epoxy log, mix up the A & B, and force that into the holes. Make sure it is flush or almost flush with the surface. When you go to reinstall the windshield, place sealant over the existing screw holes and the filled holes. That should solve the problem.
