winterizing manual head
ctcruiser
Hey all, I am winterizing my head this year instead of having the yard do it any tips for how to winterize raw water pickup and the overboard macerator I never use. I know on the raw water pickup I have read to diconnect the hose from the sea cock and put in a bucket of antifreze and then pump the head but this wont work for me as it is too hard to get to it to pull the hose off.
CT-you could probably put a hose on the water intake, but why dont you just undo the intake hose at the head and blow all the water out of it. Then just put some anti freeze into the bowl and flush that through a few times to get the antifreeze into the line tothe holding tank. You could do the same with the overbaord discharge line if you thing there is water in there.
If you leave the seacock open, it will drain the raw water out. Pour anti-freeze down the head and pump it into the empty holding tank. Turn the macerator on and pump some anti-freeze thru to the discharge. I leave all my seacocks open when on the hard.
ct:
You can do the same by 'back-flushing'. With the boat out of the water and the seacock open, pull the hose from the head. Using a funnel, pour the anti-freeze into the hose. Attach a short piece of hose to the pump on the head and pump out of the bottle of anti-freeze. Re-connect original hose. As to the macerator, you could add a few gallons of anti-freeze to the holding tank and run the system on shore if someone will hold a bucket at the discharge.
Just another Schnuk
Depending on the style of head you have, pouring AF in the bowl won't save the rest of your head from a freeze. You must pull AF through the pump section of the head.
In the past I have poured a few gallons of pink into my fresh water tank. I then power up the fresh water pump and flush the toilet a few times - this method effectively ensures that pink is running through both sides of the toilet.
while you're winterizing the head, don't forget the shower sump (if there is one). just pour some pink down it until the sump spits it out.
