Wiper problem
Arnold
How do you reach the wiper' s motor on a Sea Ray 330. It just stopped cold.
Hope this helps.
Stereo speaker and air-conditioner grilles are part of the bulkhead and headliner fabrics, which include tans, browns, parchments, and meshes. Hi-hat and indirect fixtures provide light. The sun comes in through the deck hatch forward, numerous portholes, and a pair of skylights that are fitted with fillers to match the headliner. Along with curtains and blinds for the ports and deck hatch, you can black out the interior. Another pair of fillers in the headliner reveal access to the windshield wiper motors. These are a service necessity some builders neglect. I mean, how would you feel if you asked the yard to repair a wiper and they handed you back a bill for upholstery work, too?
Arnold. I spent a small fortune trying to fix my port side wiper. First replaced the motor, then the module , In the end it never worked right. As Carver posted. the damage to the headliner was not in my game plan. So alot money spent for a poor end result. ( motor barely sweeps ) I bailed on it . ITs the port side so Co pilot is out luck.
Rob,
I had wiper motors replaced, never worked right, barely swept. Found out $500.00 later the clown mechanic put on a motor for an 18" blade, I had 24" or 26" blades. End result, burned up motor.
Ill ask my mech or lift the light panel next time I'm at the boat.
Originally posted by Harlan
Rob,
This clown did the same thing it didn't occur to me that the bigger wiper would burn out the motor I replaced the wipers with larger blades they worked for a little while and then both stopped. I now need to replace both my motors.
