Would You?
gcolton
Well-known member
Would you dock in a marina that had this in their operating instructions?
7.33. No bilge pumping in the Bens Lake/Bear Creek Marinas is allowed.
Yesterday I was e-mailed a copy of the new operating instructions. I think whoever was writing these got bilge and holding tank mixed up. At least I hope so.
G
They may be saying that they don't allow cleaning and manual pumping of bilges. If so, I could understand based on what I see coming out of mine but no way could they limit automatic bilge use to keep your boat from sinking.
Confederation Basin Marina in Kingston Ontario does not allow bilge pumping in the Marina...The reason is that the water doesn't flow freely out of the marina area and the bilge water would lay around stagnant...
How big is that basin? The size of a swimming pool!?
Cause unless it is, I can't see how you could be pumping so much bilge water into it to make a difference.
And if you are using standard packing in an inboard boat you will always be taking on some water. Then there is condensation water from aircon units. Just how are you suppost to deal with those?
I don't have that problem. I keep my boat at an old boat yard.
They understand that boats NEED bilge pumps now and then.
