In my hunt for the next boat, I go to YW, and see different specs for the same boats. Everything from the same motor with different HP, cruise and WOT way different, waste, water, and fuel capacity different, beams different, draft different.
Whats up with that???
I have seen the same ad claim different specs in that same ad, for example see below:
http://www.yachtworld.com/core/list...rl=&hosturl=redlinemarine&&ywo=redlinemarine&
OK,
Is the fuel capacity 380gal or 400 gal?
Is the water capacity 65 gallons or 90?
Is the waste capacity 44 gallons or 50
Not nick picking, but come on already, having the same ad with conflicting information makes you wonder how accurate everything else is.
As someone on the hunt for another boat, sure makes it harder, point being, this boat, 65 gallons of fresh water would not be acceptable and would not look any further at this boat.
Just saying, having the wrong specs is bad enough, having conflicting specs in the same ad makes you wonder.
PS
The link above was just an example, so not picking on Redline.
OK,
PS
