Dominic
yeah, the cockpit table is a minor issue, easily fixed obviousy.
as to the size of the ER, I'm skeptical... whether connected to IPS or a V, you cna't shrink a diesel engine and the IPS is set right behind the engine. The room saving feature of IPS comes from moving the engines all the way aft which allows for more living space. This boat takes advantage of this as you can see from teh floorplan and teh location of the aft most porthole.
now, when you look at the space aft of that porhole and remove the volume used up by the dinghy garage, there isn't a lot of room left to fit two big diesel, the IPS, the genset, the air cons, etc...
bruce, 1024 wide is more or less the standard/minimum these days, so 800 pixesl wide pictures fit nicely considering the left margin of the forum layout.
