Originally posted by L. Keith
That diesel powered pump is 24" X 21" X 18" and weights 115 pounds. If you have room for a 60 quart Yeti ice chest you have room for this pump, plus it is diesel powered and can be stowed just about anywhere. Your fixed system is still limited to having an onboard, operational power source to dewater the hull. Your suction lines are in fixed locations. You will be SOL if the boat is down by the head and your suctions are located aft in the compartments. Certified/Classed vessel are required to have a high and low suction just for that reason. A Machinery space fire puts your fixed system out of business. Interesting that the folks that dewater damaged vessels on a regular basis advocate for portable pumps. Be aware that 3,700 refers to Gallons Per Hour in a perfect setting with zero head on the discharge. Every inch that pump has to lift water out of the hull drives the GPH down very quickly, plus as the 12 volt drive motor heats up the pumps becomes less effective. That 2" pump is rated at 12,600 gallons per hour and will pump at that level as long as you keep adding diesel fuel to the tank. Ever see a competent professional salvor show up to save a boat with a couple of Rule pumps and a 12 volt battery?
