Originally posted by GeeBee
Originally posted by getakey
So would you agree there is Relative motion, but the brain blocks it out?
If there is no change in relative bearing how can there be relative motion?
if there was no relative motion, they would not collide. That's the definition of relative motion- there is a relative motion between the 2 objects. Boatbum said it correctly. 2 objects on same course at same velocity is the only case of no relative motion. Every other case, it is the sum of their relative velocities. Appearance of an object on a constant bearing does not change that fact that there is relative motion between the 2 objects
