Hi all,
I need your help.
I have a 2007 Formula 31PC with 400 hrs on the Mercruiser MX 6.2L MPI Horizon engines.
I'm looking to build out a list of things (that I can hopefully check one by one) to determine why my boat has progressively become less efficient as it relates to fuel burn. This is my fifth season with the boat (I bought it new) and in season 1 I was burning 9+ gph, during season 2 it went to 10+ gph and the 11+ in season 4 and now it's at 12.5 gph and trending up (overall I am at about 12 gph - 5000 gals over 400 hours). Some important facts: 90% of my boating is running east-west on the Great South Bay (a rather tame and predictable body of water) and I like to run at 24 knots as this is where the boat runs the most comfortably. I used to be able to hold this speed at 3200-3300 rpm but now I need to hold the engines at 3500-3600 rpm to maintain 24 knots (in similar conditions). I tried running her up this weekend and was only able to bring it up to about 34 knots at 4200 rpm max. It's been a while since I've done something similar to that but I have vivid recollection that the last time I did the same I was able to bring her up to about 36 knots easily and still felt that there was more there (I just couldn't bear to burn more fuel for no good reason).
Anyway, I just did the math this weekend so I haven't been able to investigate much but here's the list of causes/cures/suggestions I've compiled so far from various dockmates:
1) get back on your diet, Jeff (working on it)
2) finish those bottles of Kettle 1 already (took care of that this weekend)
3) When was the last time you had the waste tank emptied? (were they telling me I'm full of crap?)
4) check the props (stainless duo-props - we did a visual on them during the winter and other than tarnish they looked perfect)
5) check the bottom paint (it's supposed to be ablative)
6) have the hull checked to make sure it's not absorbing water (yikes!)
7) when was the last time I did a tune up? (never...the plugs are rated for 5 years and we pull 4 each year to check them as well as the cap and wires - they all look like new)
Does anyone want to weigh as to other possible causes and/or the possibilities on any of the above being a likely culprit?
TIA,
Jeff
I need your help.
TIA,
Jeff
