Winterized my 25 Ray, 7.4 merc yesterday after years of paying someone. Here's what I did. It's raw water cooled. Pulled the drain plugs from the block ( 1 at a time) drained the block, pulled plugs on risers to drain, took thermostat out. Put all drain plugs back in after draining. Poured about 2-2 1/2 gal af into thermo housing till block was filled. Put ear muffs on drive and ducked tape it to prevent it slipping off and spillage of af. Put a length of hose on earmuffs about 6 feet. Pulled water seperator off, ( no signs of water in it) that's what I like to see. Put a mixture of gas and 2 cycle oil in it and reeapplied seperator, Put a pint of crank-stor in oil. Son started motor while I was pouring AF into hose from 6 feet up, ran it for about 3 minutes and 6 gal af later. Disconnected batteries and put charger on them.
Comments welcome.
Joe
Comments welcome.
Joe
