I used the balsa core. The balsa is just to sandwich the 4 layers of 17 oz bi-axle. The balsa itself adds no strength. I added just as a light weight extra support. The coring with the support legs would be adequate by why not. I am adding the last two layers tonight to the horizontal supports. Then the last layer of fiber glass. Followed by finishing the edges around the plug. Lastly spray a coat on the bottom with gel coat with wax. De-molding platform plug Friday after work.
I have not weighed it but is lighter than i expected. the stairs were easly lifted onto the platform. i used about 28 yrds of 1.5oz chop mat 14yrds of 17oz biaxle 11ydrs of 3/4oz veil and about 17 gallons of resin. the Balsa which weights amoust nothing (6) 24x48" sheets
If i where to guess i would say around 150#
one item that made a big difference was the horizontal stifners in the patform. The last one i made had some flex until i mounted it and put the support legs under it. this one you could almost bolt right to the transome
The stairs with all the curvers really made a difference in strenght vs weight as well
