Hello all, it's been some time since I've posted. I recently had to replace and engine (Crusader 270) 5.7 in my 1988 Mainship Nantucket Sedan. The old motor spun a bearing 10 days before leaving on vacation, so I had to scurry. I bought a "running engine" from DaddyO's marine in Pompano Beach FL and had it shipped to CT. The "running engine" consists of a brand new motor minus the manifolds, risers, tranny, and some accessories. Got the engine in and ended up 1 day late for my Vacation. The motor seemed not to quite idle correctly from the get go, but I ran the boat to Block Island from Bridgeport CT (about 80 NM). Upon leaving Block Island, the boat stalled leaving the dock. We arrived back at Bridgeport without any incidents. The next time I used the boat, I noticed the idle was rougher than prior. I then noticed a little oil pooling at the base of the intake manifold where it meets the head, just rear of the automatic choke on the carburator. I cleaned the oil ran again, and there it was again. I attempted to tighten the nut in that location, no luck. I sprayed the area with carb cleaner and the RPMs increased. I called the place where I got the engine and they sent me a different bolt. When I pulled the bolt I suspected was the culprit, it was ever so slightly bent. I was told by someone it was likely too long which would have caused the intake manifold leak. Replaced the bolt, torqued to specs, engine still ran poorly. I decided to get a mechanic involved and he discovered no compression in 4 cylinders. Told the engine outfit and in order to have covered by warranty, I had to pull engine and ship back to FL. Got the call today that 4 valves were "mushroomed" they went over the engine, replaced the valves and are shipping back to me. Keep in mind this motor only had about 12 hours of use. Likely 12 hours with an intake manifold leak.
Their diagnosis was bad fuel. I did have fuel issues in the past, but had the tank professionally cleaned, I have a 10 micron racor, then a spin on fuel filter prior to the fuel pump, then the carb filter. I have used startron religiously and the tank of gas was fresh. They recommended getting rid of the fuel (3/4 tank about 180 gallons) and having tank cleaned again.
My concern...could the intake manifold leak have caused this and they are giving me a different diagnonis to save face? My other engine is much older and operates off the same fuel tank and it is running fine. I don't want to incur the expense of another fuel tank cleaning ($700) if they are just covering their rear ends.
I would love to hear some opinions on this?
