I spoke to a senior mechanic whom I know about the valve problems. His recommendations, assuming there is no leakage in the exhaust manifolds, are to put the engine together, leave off the valve covers and sparplugs, and leave the pushrods loose. Then, using a rachet and socket on the crankshaft bolt, run the engine though a few cycles just to make sure there's no mechanical interference caused by a timing chain problem. He doubted that would be a cause because the problem's in both engines. I should then bring #1 to TDC and check that the rotor is pointing to #1 firing position. I should then rotate the engine a little to bring all pistons somewhat down from the top of each cylinder. At that point, I should torque the rockers to set clearance. Then, once again, rotor the engine by hand. If all is clear, which it should be, I can then install the plugs, flush the fuel system, change the fuel separator filter, and connect a 6-gallon can of premiun gas. That's the plan for once I'm cleared to work again. I'm doing really well with recovery and am not using a walker anymore. I can even walk a bit without the cane, though I won't push it. Climbing down into the engine bay and lifting engine parts is still a few weeks away. To be continued. Hy
