Originally posted by jrpar
Macerator?
E/R Lights?
Shower or other sump pumps?
Thns jrpar. I got the macerator and the shower sump. E/R isn't really big 'nuff for it's own lights I don't think.
Gave it a bit more thought last night. Funny how you dream about this stuff when you should be dreaming about exotic beauties on sandy beaches in the tropics!
Forgot to add, the panel is 10" X 4" x 3mm anodized aluminum.
Here's the latest iteration
I've added a switch to interrupt all the grounds (except the crash pump) which will darken the panel.
The two rectangles are the Ancor pin terminal strips that'll be mounted on the back of the panel. One thing I learned from making the elec dist panel is you have to pay as much attention to the back as you do the front.
I see it working so all lights out until something gets turned on from the dist panel or dash switches or float switches. (except the crash pump). So normal condition is only the crash pump "amber' energized LED will be lit. When the pump activates the "red" LED will light as well as a buzzer.
The bow thruster and windlass will work similarily to the crash pump except the "green" LED will light when they're in operation.
I see this going in the overhead console on the Mate's side of the main cabin.
The panel CnC cut is about $60 US. Terminal strips $20. LED's $40. Switch $5, for a total of about $125 give or take a few sheckles. Should make a good winter project to keep my hands busy!
